DIAdem
Access violation error
Hello, I continously get the access violation error and after that immediately the ExternalException message.
The sequence of operations done by my script is:
- load matlab files into data portal (I tried Register, Load and Loadimmediately)
- rename groups
- copy some channels to a new group
- rename copied channels and add new properties
Here the error triggers and Diadem is closed...
I tried to understand what is this Oleaut32.dll file and actually it seems to be involved in a bunch of problems, but I cannot remove it because I don't have admin privileges on this machine.
Also, why should OLE programs be involved in the simple task I am performing?
(4,353 Views)
Hello mattia_verona,
Please, can you answer the following questions:
Which DIAdem version do you use?
Does the problem still occur if you do the same things but load a TDM file?
Do you use the latest Matlab DataPlugin version (1.5.07212)?
Greetings
Walter
(4,292 Views)
Hello Walter,
1) I use 2015 version
2) the error triggers only when I load .mat files
3) Up to Yesterday I was using an older version, today I installed 1.5.07212 but the error is still there
Thank you,
Mattia
(4,278 Views)
Hello Mattia,
OK, is it possible to get the Matlab file, so that we can reproduce the problem?
Greetings
Walter
(4,271 Views)
Yes, can you please share your e-mail address? I prefer not to publish the files on the forum.
Anyway: I tested my script on another computer and it works fine with the same matlab input files: I believe everything would be fixed if I uninstall and reinstall Diadem...
Mattia
(4,244 Views)
Accepted by topic author mattia_verona
Hi Mattia,
have you been able to solve the problem?
Greetings
Walter
(4,212 Views)
yes, it was a matter of reinstalling Diadem, thank you!
Mattia
(4,200 Views)
