DIAdem
Accessing DIAdem Connectivity Library with C#
How do you call the method "DDC_GetChannelGroups" in the "nilibddc.dll" correctly with c#? The method takes three arguments: 1. file handle (integer) 2. group handles (array of group handles) 3. length of array mentioned above The first argument is ok. But what kind of data structure should i pass as the second argument. I've tried Int32, but if the array contains more than one argument (even though i know there is more than one group) the method fails. How am i supposed to know how many channel groups there are in a given file beforehand anyway (this is a lesser problem though, because even when i know the exact number of groups it doesn't work).
(4,038 Views)
I had overlooked the DDC_GetNumChannelGroups method, so thats an easy way to get the number of groups, but this doesn't solve the problem, because as i mentioned above, even when i know the exact number of groups it doesn't work.
(4,031 Views)
hi slate
did you manage to connet this dll via c#?
i have this problem
http://forums.ni.com/ni/board/message?board.id=60&thread.id=11821
(3,610 Views)
