DIAdem
Active x change from 10.0 to 11.1
I have recently converted my autosequences and SUD routines to work in diadem 11.1 beta.  I switched to 11.1 release yesterday and now I am running into an active x issue in one of my sud dialog boxes.  It is basically a file browser button that once clicked opens up a file browse window.  The error is:
object 'Browse' event 'eventclick' line 10
object required comdlg.x
the script in the sud at line 10 is
comdlg.X.showopen
I didn't write this it works in diadem 10 the whole sud is real simple it opens a dialog box with a text box a browse button and an ok.  The selected file location from the browse function is fed into the text box, real simple.
the whole code:
Sub Browse_EventClick()
Dim This : Set This = Browse
' MSCommonDlgAX.X.ShowOpen
' plotfile.Text = MSCommonDlgAX.X.FileName
'Navigator.Display.CurrDataProvider.Browser.Activate()
 'plotfile.Text=Navigator.LoadData(Navigator.Display.CurrDataProvider.Browser.SelectedElements)
 comdlg.X.showopen
 plotfile.Text = comdlg.X.filename
End Sub
Sub OK_EventClick()
Dim This : Set This = OK
 plotfile_ = plotfile.Text
End Sub
the commented lines are me playing with it to no avail any help would be appreciated, I have to run with this processing code next tuesday and I really want 11.1 to work with the added injury calculations I have added to my post processing.
Regards
(4,485 Views)
I think it might just be this laptop, though it is a fresh install of windows xp and diadem 11.1.  The dialog boxes work fine on the windows 2000 pc sitting next to it.  I'll have to explore some more.
(4,484 Views)
Hello!
I'm not shure with MS Common Dialogs but MS Common Controls are only installed if MS Office or MS Visual Studio is installed (and some minor other applications).
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(4,479 Views)
and it was myfault for not installing our iso conversion controll software... ooops
(4,475 Views)
