DIAdem
Add Unit with VBS
Hi, does someone know how to add units using VBS? I am adding some new Channels, it will be great if I could add units with VBS directly rather than uns dialog box afterwards. Thanks!
Andi
(6,070 Views)
Hi Andy,
if you would like to add a new quantity to the UnitCatalog in DIAdem use this:
dim oQuantities, oMyQuantity
set oQuantities = UnitCatalog.Quantities
Set oQuantity = oQuantities.Add(Name, LengthExp, MassExp, TimeExp, CurrentExp, TemperatureExp, MolarAmountExp, LuminousIntensityExp)
If you mean to add a unit to a channel use this:
dim oChn
set oChn = Data.Root.ChannelGroups("MyGroup").Channels("MyChannel")
oChn.Properties("unit_string").Value = "MyUnit"
Greetings
Walter
(6,067 Views)
Accepted by topic author A._Baumann
thanks, I was looking a solution for the 2. case. But it´s great to kill two birds with one stone. Have a nice weekend!
(6,058 Views)
I added this code to get in-ozf as a unit.  It says it was added to the collection but I do not see it when I go to the units cell.
When using this code, is it a one shot deal and the units are now a part of the catalog or does the VBS need to be rerun.
Sure would have been nice if in-ozf would just be a standard value for torque.
Set oQuantity = oQuantities.Add("ozinf", 1,0,0,0,0,0,0)
(5,853 Views)
.... So of course after I made my initial post I find in HELP that adding a new unit can be done right in the unit cell in the properties display.  Problem is I don't get asked to add and thus get the Add Symbol dialog.  I'm using DIADEM 2012 Trial.
So I did this to make sure what I supposedly added in my previous post would be gone.
   Set oQuantity = oQuantities.Remove("ozinf")
I still don't get the Add Symbol dialog BUT I did find out that under Settings | Options | Units I could add what I needed.  I'm learning!
(5,850 Views)
