DIAdem
All.lst is created when FileNameGet is called
I am calling FileNameGet() in a SUD Dialog, which allows a user to select multiple files.  This call then sets the returned values to the T1 global variable, so I can work on the files in a Diadem script.
However, when this function is called and the file names returned, a All.lst file is created in directory, which is defined in the DIAdem Menu selection:
Settings->Options->SCRIPT
dialog as the SCRIPT user path: setting.
Is it possible to use FileNameGet() without creating the All.lst file?
Thanks.
(4,496 Views)
Hello Rich!
If you set the 6th Parameter to an empty string it should work.
Example code (from help, edited): Call FileNameGet("ANY","FileRead","C:\","TDM data (*.tdm),*.tdm", "", True, "Data selection")
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(4,486 Views)
Yes, I believe that is it, although I believe it is the 5th parameter, not the sixth.  I missed that in the Help.
Once I remove the All.lst file name from that location, it will only let me choose one file then.  Helpfull for the one file selection dialogs, but in this case I want to be able to choose a lot of files.
(4,486 Views)
Hello Rich!
Yes, the ',' in the filter confused my counter. It's the 5th parameter.
Unfortunately it is (as I know) necessary to use the file list feature if you want to get a multi select file select box. Here is a small function solving this task:
Function MultiFilenameGet(ByRef sgPath, ByRef sgFilter, ByRef sgTitle)
Dim sgFilenameList
Dim oFile
Dim asgFilenames
sgFilenameList = GetEnv(
"Temp") & "\FilenameGet.lst" ' temporary list file in TEMP folder
asgFilenames = Array()
' select files
Call FileNameGet("ANY","FileRead", sgPath, sgFilter, sgFilenameList, True, sgTitle)
If UCase(DlgState) =
"IDOK" Then
Set
oFile = CreateObject(
"Scripting.FileSystemObject").OpenTextFile(sgFilenameList,,,-2)
Do While oFile.AtEndOfStream <> True
' read single filename and store it in a dynamic growing array
ReDim Preserve asgFilenames(Ubound(asgFilenames)+1)
asgFilenames(Ubound(asgFilenames)) = oFile.ReadLine()
Loop
' release file so we can delete it
oFile = Empty
Call
FileDelete( sgFilenameList )
End If
' return filename array (empty if dialog is canceled)
MultiFilenameGet = asgFilenames
End Function
Testcode for this function:
Dim asgFilenames
Dim sgFilename
asgFilenames = MultiFilenameGet(
"D:\Programme\National Instruments\DIAdem 9.1\Libr\Dat\","TDM data (*.tdm),*.tdm", "Data selection")
MsgBox Ubound(asgFilenames)+
1 & " Files selected"
For Each sgFilename in asgFilenames
MsgBox sgFilename
Matthias
Matthias Alleweldt
Twigeater?
(4,479 Views)
My Solution for Multifileselection without creating a File. May by it helps.
Call FileNameGet("any", "FileRead","C:\Messdaten\","(*.DAT),*.DAT,(*.TDM),*.TDM","nul",True)
FileNames = Split(FileDlgFileName,"|")
For n = Lbound(FileNames) To Ubound(FileNames)
  Call DoAnythingWith(Filesnames(n))
Message Edited by OWitter on 09-29-2006 04:20 AM
(4,466 Views)
Wow OWitter!!
That's brilliant!!  How long has this been possible with DIAdem?  How did you find this out?
I'm jealous and thankful,
Brad Turpin
DIAdem Product Support Engineer
(4,457 Views)
