DIAdem
Analysis Server DDD file used?
Just a little question about the Analysis Server,
Given that the Analysis server runs a headless DIAdem instance in parallel/serial, and that DIAdem uses a .DDD file for loading its settings.
What DDD file will be loaded when a Analysis Procedure is ran in Comparative or Parallel?
This also, I am assuming will affect Worker objects.
I guess I am really asking how some of the settings in the DDD file will be configured when running worker and Analysis Packets in the Analysis Server.
Paul
(2,725 Views)
 A related question
In the DDD File for Navigator, are able to select the loading configuration.  for my use case, I will load all the file level props to the group levels.
When are running a Analysis procedure or worker, how will this setting be configured, or how should I configure it so that when the Analysis procedure runs, and loads the data the file props will be copied to group level.
(2,724 Views)
Accepted by topic author Pesmith8
I assume it would be a good idea to get rid of the settings dependencies by defining the load behavior using the import object.
Option Explicit
Call Data.Root.Clear()
Dim impParams : set impParams = Navigator.Settings.CreateImportParameter("Load")
impParams.PropertyHandling.InheritanceMode = eInheritanceMoveToLoadedLevel
impParams.LoadReturnMode = eLoadReturnGroupElements
impParams.PropertyHandling.InheritanceSeparator = ePropInheritanceSeparatorUnderscore
Call DataFileLoad(ProgramDrv & "Examples\Data\Brake_Test_001.tdm","TDM", impParams)
Call DataFileLoad(ProgramDrv & "Examples\Data\Brake_Test_002.tdm","TDM", impParams)
(2,695 Views)
