DIAdem
Anyones knows how does GraphObjDestroy work????
Anyone knows how does it work???
I tryed the following script:
Call GRAPHObjOpen("2DAxis3")
Call GRAPHObjDestroy("2DAxis3")
But it don't makes error but it don't causes any efect to may LPD file.
Someone how to make an scipt to delete a full graph ???
Thanks in advance.
(4,032 Views)
Hello mvila!
Try the 'GraphObjDelete' command instead and add a 'PicUpdate'.
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(4,029 Views)
Thanks but even updating the picture it doesn't causes any efect.
Any outher problem is observed by you???
(4,026 Views)
Hello mvila!
I forgot to say that you have to delete the 'GraphObjOpen' command.
If this still doesn't work can you please specifiy your DIAdem version.
Matthias
Matthias Alleweldt
Twigeater?
(4,024 Views)
we still work with 8.1.
 Tehanks in advance for your interss
(4,016 Views)
Hello mvila!
In 8.1 it didn't work. You can use 'Call GraphObjDelObj("2D-Axis","2DAxis1")' (no trailing GraphObjOpen!) and than save to a temporary file and reload it. Not really pretty, but it should work.
Matthias
Matthias Alleweldt
Twigeater?
(4,010 Views)
Matthias,
Thank you very much, it work but it not in the way of save and reload, it have an error when you save the LPD file. It only work updating the pic.
Else, if its possible, can you help me deleting a line of the graph???
I tryed with "GraphObjChnClear(GraphObjName) " but also it doesen't work...
thanks in advance.
(4,006 Views)
