DIAdem
Append results of ChnPeakFind instead of overwriting existing channel
I'm trying to use the ChnPeakFind() function in a script to loop through i = 1 to N channels and every ith channel append the location of the peak (result of ChnPeakFind) to the end of a result channel.  Anyone know how to do this?  My script just overwrites the value of the result channel each iteration of the loop...
(3,059 Views)
for x = 1 to 5
 set oMyChnx = Data.Root.ActiveChannelGroup.Channels(x)
  oMyChnx(chnlength(x)+1) = cch(x,2)
next
Regards
(3,011 Views)
Hi Traderhans,
Thank you for the response.  It appears the CCh() function returns the peak, but not the location (X Value) of the peak.  Still, good to know this function exists!
Chris
(3,003 Views)
