I have a problem with my app.exe build.
I attach a simple code; the Vi open and close a TDM file.
If I run this Vi in Labview works fine.
If I build the application.exe on a notebook and I run it I got "Application crash with error ntdll.dll 00018fea".
I've tried to build the Vi on another Pc Desktop with Labview and here if I run the exe it works fine.
On the two PC I have LV8.5; the build options are the same.
On the notebook I've try also to reinstall LV8.5 but I got the same error.
Can you help me?
Thanks a lot
