DIAdem
ApplicationExit Command Problem
I am facing a problem with ApplicationExit Command at run time. I get an error message as shown in the picture.
My program checks the ideal staus of DIAdem and if it crosses the ideal time set all the files open are saved and the application closes. I am using ApplicationExit to close the DIadem but have left with this error. Can any one help me quicly on this.
(3,309 Views)
This seems to be an error message from the operating system. The error could actually caused by Visual Basic Script (VBS) from Microsoft and by McAfee VirsusScan revision 8.
This problem can occur in various DIAdem versions - sometimes when you launch DIAdem and sometimes when you close it.
DIAdem assumes that VBS is used as the script language for automating repeated processes. VBS obviously does not work well with McAfee VirsusScan. Refer to the McAfee Homepage for more information.
To solve the problem, download an update of the Microsoft Windows Script Engine, free of charge.
I hope this info solves the problem.
Best regards
Walter Rick
(3,309 Views)
