DIAdem
Assign path to output files
Hi all,
I want to trying to route my files after processing to a specific folder.
Eg: C:/ Diadem/Dat files.
This is the loaction from where i am loading my data files. After processing I am getting all the text files and plots inside Dat Files Folder.
Now, Each time I load a file and process it, I want my script to create a folder called output followed by Name of file(Output_f30003) inside where I want to route all my processed files.
How can i do that......
-Rsh
(4,153 Views)
Hi RSH,
These are the commands you need, along with the VBScript string concatenation operator "&":
FolderExist
FolderCreate
NameSplit
DataFileSave
Brad Turpin
DIAdem Product Support Engineer
(4,135 Views)
Hi Brad,
Can you please send me a sample code for this.
I am generating text files, pdf file and wmf file.
As soon as the text files are created I want to create a folder inside the folder from where i load my Dat file : eg C:/Script/DatFile/Text files
similarly for pdf files : C:/Script/DatFile/PDF Files
for Wmf files : C:/Script/DatFile/WMF Files
Please suggest me how do i go abt this..
May be, when Text files are generated, create folder Text Files inside dat file and  Specify path for text files....
rsh
(4,122 Views)
Hi Rash,
Please post the VBScript you already have to load the data file, and I'll see what I can add to it to facilitate folder and file creation relative to the load path.
Brad Turpin
(4,112 Views)
