DIAdem
AutEdWSSave raises an error on execution.
I'm trying to save the current workspace using "AutEdWSSave" command, but on running this command it raises an error and the message says "The command cannot be executed because a VBS - AutoSequence or Debugging is running". How do i avoid this? I need to save the workspace by executing .VBS file, which has the script to save the workspace.
(4,053 Views)
Sorry, but currently you can use the command "AutEdWSSave" only if you are working interactivly. We will look whether we can change this behabiour for further DIAdem versions.
Greeting
Walter Rick
(4,053 Views)
Thanks..
(4,053 Views)
Thanks Walter, would please you explain how it could be used interactively.
cheers,
Raja
(4,053 Views)
With a right click on the file overview window (in DIAdem 9 you can open this splitter window via mouse) you get the context menu to "save workspace as...".
Please follow the attached screenshot.
Greetings
Walter Rick
(4,053 Views)
Hi mv_rajk,
You can also simply select "File>>Save workspace as..." from the pull-down menu in DIAdem-SCRIPT.
Brad Turpin
DIAdem Product Support Engineer
(4,053 Views)
