DIAdem
Average with a another X-Channel
I'm new to diadem and have a small problem so I was wondering if you could help.
I m using diadem to maque Troque curves.
I would lique to have 2D Axis system showing on Y-axis the average of multiple torque curve and on the X-axis the rpm of the engine.
But when I use the Average Channels fonction it does average the curve using the time base.
I tried to convert my numeric channel in waveform with the RPM channel as the X channel so I would have the same rpm base for the average fonction.
This doesn't work and returns: " the x-channel must be equidistant ".
Please apolagize for the bad english, I'm not a native speaker.
David
(5,611 Views)
Well i was doing something wrong.
There is no plroblem
The thread can be delete
(5,582 Views)
Thanks David for letting us know. I will close the request
Rik Prins, CLA, CLED
Software Development Engineer
(5,566 Views)
