DIAdem
Averaging data on specified pattern
Hi. I need some help with an script. I am doing 360° with a pattern(+1° ; -0.5 °; +1° ...) and the frequency is 1.6 kHz. I want to do an arithmetic mean on every 4000 Hz samples and to store the values in another channel. I have attached a graph with how the data looks like. Regards
(2,484 Views)
Accepted by topic author Emilian.M
Option Explicit  'Forces the explicit declaration of all the variables in a script.
'''''''''''''''''''''''''''''''''''''''''''''' * GENERATE FAKE DATA - START * ''''''''''''''''''''''''''''''''''''''''''''''
Call Data.Root.Clear()
Data.Root.Name = "Example"
Dim DataGrp, DataChnl, i, j
Set DataGrp =  Data.Root.ChannelGroups.Add("Data")
Set DataChnl = DataGrp.Channels.Add("360", DataTypeChnFloat64)
DataChnl.Values(1) = 0
For i = 0 To 999999 Step 1
  If DataChnl.Values(DataChnl.Size) >= 360 Then
    Exit For
  Else
    For j = 1 To 1600 Step 1
      DataChnl.Values(DataChnl.Size + 1) = DataChnl.Values(DataChnl.Size) + 0.000625
    For j = 1 To 800 Step 1
      DataChnl.Values(DataChnl.Size + 1) = DataChnl.Values(DataChnl.Size) - 0.0003125
  End If
'''''''''''''''''''''''''''''''''''''''''''''' * GENERATE FAKE DATA - END * ''''''''''''''''''''''''''''''''''''''''''''''
' Generate the mean channel
For i = 1 To DataChnl.Size Step 4000
  Call ChnStatisticsChannelCalc("" & DataGrp.Name & "/" & DataChnl.Name, 32, i, i + 4000, False, True, False, "NameName")
  If DataGrp.Channels.Exists("ArithmeticMean1") Then
    DataGrp.Channels("ArithmeticMean").Values(DataGrp.Channels("ArithmeticMean").Size + 1) = DataGrp.Channels("ArithmeticMean1").Values(1)
    Call DataGrp.Channels.Remove("ArithmeticMean1")
  End If
(2,444 Views)
Thanks a lot @gsklyr. Its doing exactly what I need it. Best regards
(2,428 Views)
