DIAdem
Axis AutoScaling Begin/End Manual + End/Begin Automatic Bug
We've recently discovered a bug in DIAdem 2021 SP1 when using 2D graphs where the X or Y axis has:
  • .AutoScalingType=eAxisAutoScalingBeginManualEndAutomatic
    • .Begin > maximum channel value
  • .AutoScalingType=eAxisAutoScalingBeginAutomaticEndManual
    • .End < minimum channel value
DIAdem will lock up when refreshing the REPORT, and no error message will be put into the log.
I've attached a script that demonstrates this (with commented out sections for each channel/axis).
-Josh Rewerts
(1,887 Views)
Hi Josh,
Thank you for your feedback. We did not know about this bug. I have forwarded it to R&D so that they can fix it.
Thank you
Walter
(1,861 Views)
