DIAdem
Axis name of 2D Axis system
Hello NI staff,
I got a problem when I tried to configure axises of a 2D-Axis system. For example, Select the X axis of a 2D-Axis system, name of the selected axis appears on DIADem status bar, but I can not operate this axis in Script with the proposed name.
How can I get the right name of a report component which can be used in script for operation of this component?
Please refer to attachment for more information.
Best regards
Somewei
(4,143 Views)
Hello Somewei!
Open the axis dialog, press Ctrl+A and paste the result in a text file. There you sholud see how to access the object. You will see the name is right but it is a sub object of the axis system and you have to open this first.
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(4,138 Views)
Hello Mr. Matthias,
Thanks so much for your reply, it works, I got all the configurable items by pasting them on a TXT file, of course name of the axis. Name of the 2D-Axis system is "2DAxis1", so I thought name of the X-Axis of this 2D-Axis system must be "2DXAxis1_something", but actually the right name is "2DXAxis65_1", here you can see. Thanks again.
Call GRAPHObjOpen("2DAxis1")
  Call GRAPHObjOpen("2DXAxis65_1")
    D2AXISXDIVMODE   ="linear"
    D2AXISXSCALETYPE ="complete automatic"
    D2AXISXBEGIN     =0
    D2AXISXEND       =60
    D2AXISXORIGIN    =0
    D2AXISXTICKDIST  ="calculated from tick space"
    D2AXISXTICK      =10
    D2AXISXTICKCHN   ="[1]/Time"
    D2AXISXMINITICK  =1
    D2AXISXTICKTYPE  ="top"
    D2AXISXTICKCHNN  =""
    D2AXISXTICKCHNF  =""
    D2AXISXTICKCHNC  =""
  Call GRAPHObjClose("2DXAxis65_1")
Call GRAPHObjClose("2DAxis1")
Somewei
Best regards
(4,131 Views)
After opening the 2d-axis object you can open the first x-axis with the following code:
Call GraphObjOpen(D2AxisXObj(1))
Ton
My LabVIEW Ideas
(3,537 Views)
