DIAdem
BUG ChnPropCreate DatatypeEnum and DataTypeUnknown dont work!
Hi at all,
If I want to create a property with datatype Enum or Unknown I get an Error. The other datatypes are working.
The yellow marked datatypes are not working:
I get this error:
Diadem version I use:
Does anyone know if this is fixed in Diadem 2010?
Kind regards
Tanja
(3,618 Views)
Hi Tanja,
It looks like we need to improve DIAdem's documentation.  The errors you're getting are by design-- a VBScript is not permitted to create a property of type enumeration or unknown.  DIAdem itself creates a few properties of type enumeration, so you'll run into those, but you can't create them.  The unknown data type is just there for the case that DIAdem reads a property from a file but can't determine its data type from the info in the file (remember DIAdem reads hundreds of different file formats, many of them ASCII formats that aren't super-reliable).  No property is supposed to exist with the data type unknown, so DIAdem won't let you create one that way.
I understand the interest in creating an enumeration property, but it is simply not implemented at the moment for a user to crate enumerated properties.  You can create enumerated variables with the old VAS file approach, but I personally find that approach more trouble than the enumeration variable is worth, and there is no way to turn such an enumerated variable into a File/Group/Channel property, so that doesn't help you with your goal.  I'm afraid you either have to create an integer property or a string property (or both) as an alternative way to store the information you'd prefer to save as an enumeration property.
Brad Turpin
DIAdem Product Support Engineer
(3,604 Views)
