DIAdem
Blank Spaces in TDMS file Properties
hi,
I want to re write the property  (in labview )" Storage date/time  "   with the actual value(datetime)
but what does diadem expect the property name to be  as    it doent accept  blank spaces  etc (converts everything to "_"      😞
is there any trick for this  how to insert  the propertyname.
names without  blank r not an issue
(5,942 Views)
Script name datetime
for this Storage Date/Time  the Script name is given (also for all other props)
its mentioned in   Help
tht solves the issue
(5,938 Views)
DIAdem has display names. The real name of the property can be seen if you drag and drop the Property int diadem script.
So dragging "Storage date/time" results in
Data.Root.Properties("datetime").Value
 Which means the real name is 'datetime'.
(5,936 Views)
Hi aparab,
        like Andreas asked, it's neccessary to know ehich property you mean.
        How do you write this property in LabVIEW? Which result do you get in DIAdem?
Philipp K.
AE | NI-Germany
(5,898 Views)
Hi aparab,
Check out this white paper that talks about this property and lots of other points regarding writing TDMS files with LabVIEW that work well with DIAdem and the DataFinder.
https://www.ni.com/en/support/documentation/supplemental/12/writing-data-management-ready-tdms-files...
Brad Turpin
DIAdem Product Support Engineer
(5,888 Views)
