DIAdem
Bug: Report Manual Adjust Y-scaling decimal values
I'm unable to set manual scaling for a diagram in report generator if the begin or end values contains decimal values. Integers works fine.
If I try to set a decimal value in the report generator properties window, it resets the value to last integer value.
It's possible to set decimal values with script i.e.
o2DAxisSystem.YAxis.Scaling.AutoScalingType = dd.eAxisAutoScalingManual
o2DAxisSystem.YAxis.Scaling.Begin = 0
o2DAxisSystem.YAxis.Scaling.End = 14.5
dd.Report.Refresh
Diadem Version: 2023 Q4, Build number: 23.8.0f9035
Message 1 of 1
(413 Views)
