DIAdem
CPK with one limit
Does DIAdem have a way of calculating process capability with only one limit. This can be done in Minitab, but I've been unable to find reference to a way of doing it in DIAdem. The way I'm getting around it now is to calculate the second limit based on the data, then calculating CPK.
James
(5,750 Views)
I am not completely familiar with this calculation and the statistics operations that it performs. This help documentation discusses the results that are processed from this calculation:
http://zone.ni.com/reference/en-XX/help/370858K-01/dlgmaths/calc_statistics_dlg/dlgspcprocesscap_dia...
It looks like the pictures referencing the calculations are broken but the all of the variables that store the results are shown.
Ian M.
(5,732 Views)
That is the reference to how to calculate Process Capability with two limits. Not very helpful (unless I'm missing something).
(5,723 Views)
Looking at the documentation I sent you the SPCCpU and SPCCpL are the one sided upper process capability index and the one sided lower process capability index. From what I understand, isn't that the information you are looking to calculate?
Ian M.
(5,709 Views)
