DIAdem
CSV Data Plugin for headers that are 305 lines long.
Hello All,
I have to write a Data plugin for loading a CSV file where the header takes up the first 305 rows then the data starts, using the wizard it caps the line assignments at 200, how do i go beyond that? I have attached a sample file.
(957 Views)
Hello dkrispin,
Unfortunately, the Text DataPlugin Wizard only shows the first 200 lines in the first step, so that you cannot select your data range, which starts at line 305. The wizard creates an encrypted DataPlugin script so that you cannot edit it later. As the start line of your data block may not always be identical, I recommend creating the DataPlugin yourself.
This could look like this. In this example, which I have created for you, the two areas [Comment Fields] and [Graph Settings] are read in by creating the lines as properties at the root. When the file reader reaches the data area [Data], the channels are read in and created in the Measurements group.
Const HeaderData = "[Data]"
Sub ReadStore(File)
  dim FileInfos
  set FileInfos = CreateObject("Scripting.Dictionary")
  call FileInfos.Add("[Comment Fields]", array(",", eString))
  call FileInfos.Add("[Graph Settings]", array("=", eString))
  File.Formatter.LineFeeds       = vbNewLine
  File.Formatter.IgnoreEmptyLines= true
  File.Formatter.TrimCharacters  = " "
  File.Formatter.Delimiters      = ","
  dim LineText, PropertyName, PropertyValue
  dim ChannelGroup, ChnNames, ChnIdx, Chn, Units
  dim FilePos
  do while (File.Position < File.Size)
    LineText = File.GetNextLine()
    ' Read properties
    if FileInfos.Exists(LineText) then
      File.Formatter.Delimiters = FileInfos(LineText)(0)
      FilePos = File.Position
      PropertyName = File.GetNextStringValue(eString)
      do while left(PropertyName, 1) <> "["
        PropertyValue = File.GetNextStringValue(FileInfos(LineText)(1))
        call Root.Properties.Add(replace(PropertyName, ".", "~"), PropertyValue) ' Create grouped property with ~
        call File.SkipLine()
      loop
      File.Position = FilePos
    elseif LineText = HeaderData then
      ' Read channel data
      set ChannelGroup = Root.ChannelGroups.Add("Measurements")
      ChnNames = split(File.GetNextLine(), ",")
      Units = split(File.GetNextLine(), ",")
      File.Formatter.DecimalPoint = "."
      dim Block : set Block = File.GetStringBlock()
      for ChnIdx = 0 to ubound(ChnNames)
        set Chn = Block.Channels.Add(ChnNames(ChnIdx), eR64)
        call Chn.Properties.Add("unit_string", Units(ChnIdx))
        call ChannelGroup.Channels.AddDirectAccessChannel(Chn)
      next
      exit do
    end if
  loop
End Sub
Save the source code as a VBSD file and register it as a DataPlugin. Customize the code to your needs.
(901 Views)
Thank you for the help I will work on it today and post the results.
(890 Views)
