DIAdem
CTNV with x-channel of Waveform
I have a waveform in DIAdem which is say 30s long. In a script I would like to convert a section of data between say 0s and 4s to NoValues.  If I was doing conversion based on y-values then I would the CTNV function. However I can't a find a way of doing this based on a time interval. I know I can do it in View using the cursors but I need to be able to script it with no user intervention.
Can anyone help please?
Martin
(5,345 Views)
Accepted by topic author MartinMcD
Hi Martin,
I'm afraid your best bet is to temporarily create a time channel from the waveform properties.  Assuming you're starting with a channel object variable for the YChannel in question, this is what it would look like:
ChanList = WfChnToChn(YChannel, TRUE, "WfXRelative")
L1 = CNo(ChanList(0))
L2 = YChannel.Properties("Number").Value
R1 = 0
R2 = 4
Call Calculate("Ch(""New YChannel"") = IIF(Ch(L1)>=R1 AND Ch(L2)<=R2, Ch(L2), Null)")
Call ChnDel(L1)
Brad Turpin
DIAdem Product Support Engineer
(5,322 Views)
Hi Brad,
Thank you very much for the reply. I had forgotten how you could use the variables and IIF function within Calculate to operate on whole channels like that, fantastic.
I made one which I guess was typo to anyone else following which was 'L2 = YChannel'.
Thanks again,
Martin
(5,309 Views)
