DIAdem
Calibration Measurement timeout
Hi there,
i have some troubles with the calibration measurement of a scaling block. If i try to make a calibration measurement with software timing, what worked perfectly in the past, i get values that look a lot more like a novalue replacement than anything else. If i use hardware timing it takes a long time but the values seem to be correct. Is there anything that has to keep in mind to get this working with software timing again? I use the gpi-dac driver for ipetronik version 3.04 as Input. I also tried higher versions with the same result.
Thanks a lot
diademi
(3,571 Views)
Hello diademi,
I tested the calibration measurement in software timing with DIAdem 2010 SP1 and NI hardware. This works fine. For this kind of measurement the device driver is called. The driver for Ipetronk hardware is developed by Ipetronik itself and because I neither have this hardware nor the device driver I couldn’t test it. I’m not sure whether the problem is caused by the driver; I just can say the above scenario works fine.
Greetings
Walter
(3,559 Views)
