DIAdem
Call Help File (.chm) then run setup file
Hi!
When I coding a program, I click a Button on Front Panel and can call a Help File. But when I Build Aplication and add help File on Source File then run Setup File, I click button and can't call Help File.
Thanks for your help!
My code
(3,777 Views)
Can you document your code and include labels for the VI's? The code doesn't seem to reflect your questions. Can you explain how you're calling the Help File? Are you doing it programmatically or from the file menu of the executable?
Product Support Engineer
(3,759 Views)
