03-16-2022 11:36 AM
I am trying to remedy a bug where my values are incorrectly being pulled after processing data. I have found the only reliable way to do this is to press the green refresh values button over the data portal. I am trying to include this step in the script, is there any way to do so. From my understanding it calls the CalculationSet manager which recalculates all the channels maxes. Which is different from the Portal.Refresh which I believe is only UI not the actual channel values. Thank you for the help!
Solved! Go to Solution.
03-17-2022 05:04 AM
Hi BrandsonHosken,
We don’t have a corresponding script command for the green refresh values button. But I have created a small script which works in the same way.
First, I search for all calculation channels and run the calculation and in the end, I calculate the channel characteristics for all channels.
dim iLoop, jLoop, oGroups, oGroupChns
set oGroups = Data.Root.ChannelGroups
for jLoop = 1 to oGroups.Count
set oGroupChns = oGroups(jLoop).Channels
for iLoop = 1 to oGroupChns.Count
if oGroupChns(iLoop).IsKindOf(eDataCalculationChannel) then
call oGroupChns(iLoop).RunCalculation
end if
next
next
call ChnCharacterAll
Greetings
Walter
03-17-2022 08:04 AM
Perfect, thank you so much for the help with this problem! I appreciate it!
