09-07-2011 10:22 AM
Hey Brad, Nate -
Brad, your code references the selection of channels and groups in the Data Portal. I may be confusing this with prior posts, but I'm pretty sure Nate is attempting to figure out which channels a user has selected in a Listbox within a SUD nested in VIEW.
Nate, which are you trying to do?
If the latter, you'll need to adjust Brad's code accordingly.
09-07-2011 12:00 PM
Im attempting the latter, like you are specifying Derrick. Also in Brads code, if Im not mistaken:
Length = Channel.Properties("Length").Value
Wouldn't this just return the length of the channel (i.e. There are 15000 cells in this channel)? Im looking for the specific value in the cell location not where the cell location is at (i.e. What is the value located @ cell 15000).
~Nate
09-08-2011 07:45 AM
LastValue = Channel.Values(Length)
09-08-2011 05:01 PM
Brad,
You're methodology should work the only issue I am having is that I am making my selections from a listbox that then references the Internal Data Portal and I cannot seem to do the following because the value is not an object:
Set Selection = selectData.MultiSelection(j).Index
Is there a work around for this?
~Nate
09-09-2011 12:07 PM
Ok so I figured out a work around that is a bit tedious but it does exactly what I want it to do so I'm happy for the time being.
1.) ChnAlloc new Channel with a single value.
2.) Call DataBlClpCopy("'" & selectData.MultiSelection(j).Text & "/**bleep** Fuel Used", 15018, 1)
3.) Call DataBlClpPaste("'" & selectData.MultiSelection(j).Text & "/Total Fuel Used", 1, 1)
4.) Call View.Sheets("Total Table").Areas("Area : " & Counter).DisplayObj.Columns.Add("Total Fuel Used")
And viola channel outputs to total table with just a single value and all channel properties
Thanks for your help guys,
~Nate
