DIAdem
Can Converter
Bonjour,
je n'arrive pas convertir mes  fichier de type "vector ASCII" (.asc) avec ma ma bus database configuration (.dbc):
Il m'indique ce message d'erreur : "can converter error : invalid number of data bytes"
Je ne comprend pas alors que j'arrive à l'ouvrir avec le logiciel Can graph Vector .
Cordialement
vP
(3,521 Views)
Hi vP,
I'm not yet sure what the problem is.  I'm thinking that either your Vector log file (*.asc) has a data type or lookup code type that the DIAdem CAN Converter does not yet support, or perhaps the configuration you entered for looking up values from the Vector data base (*.dbc) is not consistent with what is actually in the Vector data base.
Is there any chance you could post or email me (brad.turpin@ni.com) those files so that I can ask R&D to look into this for you?
Brad Turpin
DIAdem Product Support Engineer
(3,516 Views)
