DIAdem
Can I prevent a user from closing a SUDialog?
I have a SUDialog that starts some processes and I'd like the user not to be able to close the dialog until these processes are finished, or until the user cancels them.  How can I do this?
Thanks!
(3,473 Views)
I suspect you are referring to modal dialogs You may find the following help page quite useful:
DIAdem 2015 Help: Modal and Non-Modal User Dialog Boxes
(3,384 Views)
No, I have a non-modal SUDialog that is open and sometimes showing updates from an outside process.  I'd like the user to be unable to cancel this until this process is finished or cancelled.
I tried adding something in the EventTerminate action, but am not sure how to get out of the EventTerminate (which is initiated if the user presses the "x" at the upper right corner of the dialog."
(3,377 Views)
Accepted by topic author JuliaDawkins
Please check help of the
EventQueryClose
event which can be used for this use case.
(3,371 Views)
this works, thank you!
(3,361 Views)
