DIAdem
Can I write code in vb6 to export data to a .tdm file?
I'm trying to figure out how to export data directly to a .tdm file using vb6 code.  Do I need to create data in another format and then import to .tdm?
(4,812 Views)
Hi Carlos,
TDM files are a standard that National Instruments created, and so there really is no functionality in Microsoft's Visual Basic to write to that file format.
The only feasible way I can think of would be to create a DLL from LabVIEW that uses the Data Storage VIs, which you can then call from your VB6 application.
Are you looking to take data acquired from VB 6 and bring it into DIAdem? If so, then for just about any format you write to from VB 6 ... with the use of a Dataplugin in DIAdem you can import the data in the TDM format Groups and Channels.
For more information on DataPlugins with DIAdem, check out DataPlugins website. This lists a good number of DataPlugins already in existence for DIAdem. You can, however, write your own should you have a format not already supported.
Hope this helps Carlos, have a good one!
Dan Weiland
(4,802 Views)
Hi Carlos,
If you want to take LabVIEW out of the loop, you can create a TDM Header file for an existing binary file you write in VB by using the TDM Header Writer DLL, which you can find (fully documented) at the following link:
http://zone.ni.com/devzone/conceptd.nsf/webmain/AE11F7A38E8356FD8625709900505D72
Brad Turpin
DIAdem Product Support Engineer
(4,773 Views)
Hi !
I can understand that VB6 seems obsolete to you, but a) it was a great tool and b) thanks to the "DAQmx C API", new devices could be run with it.
What is the reason that writing TDM(S) files is not a part of NI-DAQmx standard functions ?
In that case (I assume that) VB6 programmers could intergrate it their code...
Dimitri
(3,666 Views)
