DIAdem
Can data be saved as CSV without Channel headers?
I am saving to CSV using:
Call DataFileSaveSel("<filename>" &"C:\NameOfFile.csv"&"</filename>","CSV","'myFiles/Angle', 'myFiles/lift'")
this works fine giving data as below
Angle lift
0   0
0.1   4.525e-005
0.2   0.000181
0.3   0.00040725
0.4   0.000724
0.5   0.00113125
For one application however, i can't use the file without going in and removing the headers ('Angle lift') first.
Is there a way to save the file without headers?
(4,257 Views)
Hi chrismcc,
this is possible. Please add a new parameter after filename as follows:
Call DataFileSaveSel("<filename>" &"C:\NameOfFile.csv"&"</filename><channelnames>no</channelnames>","CSV","'myFiles/Angle', 'myFiles/lift'")
(4,249 Views)
Thanks usac that does the job.
Is there a listing of possible parameters anywhere?  I couldn't find one.
(4,239 Views)
Hi Chris,
This is what I have squirrelled away.  I don't know how comprehensive it is, and I don't think I've ever used "timeformat" for export, but hopefully all you really need is here.
"filename"         specifies the file that is to be read.
"delimiter"         is the character used to separate values. I think only tab, semi-colon, and comma are supported.
"decimalpoint"  indicates whether a "." or a "," is used to separate the integral part of the number from the fractional part.
"timeformat"     indicates what time format to expect in the document and how to write the time format back out again.
Brad Turpin
DIAdem Product Support Engineer
(4,196 Views)
