DIAdem
Can not drag data file from file explorer in to data portal
I recently upgraded diadem to 2017 64 bit and i am no longer able to drag files from windows file explorer into the data portal. I did not have this issue with diadem 2015.
I have uninstalled diadem reinstalled diadem, I have tried resetting the the DataFinder and i am not sure what else to try.
If anyone can lend some help I would sure appreciate it.
(2,685 Views)
Hi jon.bleakney,
I check that with the latest DIAdem 2018 version as well as with DIAdem 2017 SP1 and it works fine.
Greetings
Walter
(2,646 Views)
Hi Jon,
I have noticed for many many DIAdem versions that if I choose to launch DIAdem with the "Run as Administrator" option, that I am not able to drag&drop files from Windows Explorer.  When I shut down that DIAdem instance and start up a new instance normally, I can drag again.
Any chance you started launching as Administrator recently?
Brad Turpin
DIAdem Product Support Engineer
(2,617 Views)
Brad,
Thanks for the response. I have not been running Diadem as Administrator, but for fun i tried to run it as administrator but sadly ended up with the same results.
Thanks for you feed back
(2,609 Views)
