DIAdem
Can't create group
I'm using Diadem 2024-Q2.  Yesterday my script stopped working - the first thing it does is add a Group called "Calculated".  It did not add this group nor any calculated channels.  I then tried to manually add a group and it won't - there are no error messages. I tried repairing the install and also recreating my TDMS file, but nothing helps.  Any suggestions?
(640 Views)
OK, I narrowed it down. Every once in a while, I get this error below.  I am using User Commands, but when I get the error, Diadem seems to error even if I remove or comment my changes. I guess this is just a quirk of the program.
(622 Views)
