DIAdem
Can you save or export data to a database with DIAdem?
I want to be able to save/export data that I load and analyze with DIAdem to a SQL Server db.  Can DIAdem export to a db?
Thanks you.
(5,048 Views)
Hello jcn,
Yes, DIAdem can communicate with any SQL/ODBC and ADO compatible database.
The commands are listed in the DIAdem Help System. If you don't have DIAdem installed, you can search the DIAdem Help System online on our Website here:
http://zone.ni.com/reference/en-XX/help/370858K-01/
There is also an example in the DIAdem help system based on an ADO, if you have DIAdem installed you can find that example under
DIAdem Example Finder: Examples>Creating Scripts>Using Interfaces>ADO Database Application
We also have a SQL Wizard that we can provide free of charge if you provide your email address to me.
I can be contacted via the following email format:   FirstName.LastName@ni.com
Let us know if you have additional questions,
     Otmar
Otmar D. Foehner
(5,038 Views)
