DIAdem
Cannot create new analysis procedure
I just upgrade to Diadem 2019 SP1 From 2018.  When trying to start a new Analysis Automation Procedure, I get the following error after clicking ok in the “New Analysis Automation Procedure” dialog box.  This is the dialog box where you enter the Name, Description, and Author of the Procedure.
     Error in <TdmServerSuite_AnalysisServerConfig.SUC,AnalysisServerConfig> (Line: 611,Column: 5):
     SUD event context:
       btPacketNew_EventClick(...)
     Error in included script file <C:\PROGRAM FILES\NATIONAL INSTRUMENTS\DIADEM 2019\Resource\TdmServerSuite_AnalysisServerSimulation.VBC> (row/column) (611/5):
     SUD event context:
     Object required: 'oDlgASConf_M'
Any suggestions?
(2,695 Views)
Using the repair functionality of the DIAdem installer should solve the issue.
-Dirk
(2,512 Views)
Hi Dirk,
Russell uninstalled DIAdem and then reinstalled using the NI Package Manager this time, and the problem went away.
Brad Turpin
Senior Product Support Engineer
(2,439 Views)
