DIAdem
Cannot open TDMS file via script, but I can manually with data portal
I am trying to open a TDMS file via script:
' Clear the data portal and load the data
Call Data.Root.Clear()
Call DataFileLoad(file_path,"TDMS", "Load")
Call LogfileWrite("TDMS data file loaded: " & file_path)
I get the following error:
22   11:18:19 Error:
     Cannot load the file "\\XXXXXX\fti_20241106104514_pp.tdms" with the loader "TDMS".
     Further information:
     Cannot open the file  "\\XXXXXX\fti_20241106104514_pp.tdms".
Also, a .tdms.log file is created, with the following info:
***************** New logfile section *******************
TDMS: ERROR: TDS Exception in Initialize: Tds Error: TdsErrAccessDenied(8):
The funny thing is: if I drag and drop the EXACT same file in the data protal, it works just fine.
So why do I get an access denied error when opening the file via DataFileLoad, but not with a drag and drop in the dataportal?
Thank you,
Jacques
(634 Views)
Are your sure that the file referred to in file_path is the same as the one you load manually?
Did you try to record a script when loading the file manually? If you run this file, does it work?
And as always: sharing the file could be helpful.
Holger Müller
DIAdem experience since 1996
Turn-key applications - Remote and on-site trainings - On-the-job training
| müller+krahmer GmbH | Koenitzer Straße 14, 07338 Kaulsdorf / Germany |
| Phone: +49 36733 / 2328 - 6 | Mobile: +49 160 / 287 7294 |
| Email: mueller@mueller-krahmer.de | Web: www.mueller-krahmer.de |
(599 Views)
