DIAdem
Cant import TDMS files with DataFinder in Script
Hi everyone,
i'm fairly new to DIAdem and am currently trying to import TDMS files with a script.
I took the example from http://zone.ni.com/reference/de-XX/help/370858P-0113/scriptnavi/objects/navigator_objects_idatafinde... and adjusted it to my files. However, the script will not load any of my files. If i try the same with DIAdem example files (TDM), it seems to work. Is the DataFinder only capable of importing TDM and not TDMS files or am i missing something?
Greetings
(2,493 Views)
This should work with tdms.  Are you getting an error or does your script simply not load anything?  It would be helpful to see your code and understand the exact error or wrong behavior.
(2,414 Views)
