DIAdem
Cant read MF4
Hello all,
I try to open mf4 file but I cant do it. I installed the pluggin here's
http://www.ni.com/example/54290/en/
Then, I got this message:
Any idea what happens ?
(2,147 Views)
Hi Jeremy,
I have used that plugin quite a lot, and have never had any problems.
Some tips:
* Can you check if that file is not corrupted? Are you able to open with INCA MDA?
* If you can open it with MDA but not with DIAdem, perhaps there are some strange channels, rasters, or whatsoever not correctly managed by DIAdem mf4 plugin. By the way, is that the only file you're not able to open? Or are there other acquisitions you were able to import?
(2,087 Views)
Hi, did u find the problem?
i got same problem in Diadem2020
(1,867 Views)
