DIAdem
Change Data Types (eR64 to eTime)
Hello Together,
I am new to Diadem and VBS and have a question regarding changing the data types. I am reading data from a CSV-file. So far its working good, but I am not able to get the time right.
The input file is in this format:
T, 1380723715680 '1380723715680 = Start time in ms (Computer Time)
H, Name1, Name2, Name3 ' First column time in ms after the Start Time
H, REAL, REAL, REAL
0, 0, 0, 0                          ' First data line
200, 20, 50, 100                ' second data line 200 ms after the first one
I can read out and convert the start time by:
File.SkipValue() 'Skip "T,"
TimestampMS = File.GetNextStringValue(eString)
StartTimeDate = DateAdd("s", TimestampMS / 1000,  "01/01/1970 00:00:00")
 This gives me the right time and date information. In this example 02.10.2013 14:21:55 I can also easyly setandreadoutthechannelinformationandcontainingdata.
But I don't manage to get the time information in a way of Offset + ms value and convert it to Time and Date information. I only manage to sum up the ms value with the offset as an eR64 value. How can I convert this than to eTime?
Any help or better idea?
Message 1 of 12
(8,210 Views)
Hi BenniL,
I don't exactly get, what you are doing.
There is a vbs function "createTime" which returns a Time Object.
Does this helps?
Kind Regards,
Philipp K.
AE | NI Germany
Message 2 of 12
(8,168 Views)
Hi BenniL,
The VBScript datetime functions only work down to the second level.  Try instead the DataPlugin command:
Set DateTime = File.Formatter.ParseString(StringVariable, eTime)
DateTime.Millisecond = TimestampMS
Brad Turpin
DIAdem Product Support Engineer
Message 3 of 12
(8,152 Views)
Thanks for the replies!
Unfortunately I don't understand the answers or get anything working by trial and error. Maybe I try it again with minimal input file to clarify my goal. I guess my question is just too simple.
With this as the input file
1314117549640 'Start time in ms
Timer, MeasuredValue 'Description of the measured values
0,11 'Data Line 1
200,22 'Data Line 2
400,35 '...
600,65 '...
Sub ReadStore(File)
  'Dateiformatierung
  File.Formatter.LineFeeds        = vbLf
  File.Formatter.IgnoreEmptyLines = true
  File.Formatter.TrimCharacters   = " "
  File.Formatter.Delimiters       = ","
  File.Formatter.DecimalPoint     = "."
  '1314117549640
  Dim StartTimeMs, StartTimeDate
  StartTimeMs = File.GetNextStringValue(eString)
  StartTimeDate = DateAdd("s", StartTimeMs / 1000,  "01/01/1970 00:00:00")
  Call Root.Properties.Add("Start of Measurement", StartTimeDate)
  Call File.SkipLine()
  'Create group with file name as description
  Dim Gruppe : Set Gruppe = Root.ChannelGroups.Add(File.Info.FileName)
  Dim Block : Set Block = File.GetStringBlock()
  'Time, MeasuredValue
  Dim Kanalname, Kanal
  Set Kanal = Block.Channels.Add("Datum und Zeit", eR64)
  Kanal.Offset = StartTimeMs 'Works even StartTime is a String. Why?
  Gruppe.Channels.AddDirectAccessChannel(Kanal)
  Kanalname = File.GetNextStringValue(eString)
  Set Kanal = Block.Channels.Add(Kanalname,eR64)
  Call Kanal.Properties.Add("unit_string","%")
  'Ab hier die Daten
  Block.Position = File.Position
End Sub
 And this as the DataPlugin I get two channels with the results as I expect.
How can I now change the first channel to eTime and represent it in Minutes, hours, seconds, milliseconds or whatevere?
Any help or recommendations?
Message 4 of 12
(8,129 Views)
Hi BenniL,
Your file snippet shows a first line where the start time = 1314117549640 ms.  What is the reference date-- since 1900, or 1904 or 1970?  Is the first channel in your data file always the relative time?  Is the first channel also measured in ms?
There is a trick in the DataPlugin API to turn a numeric channel into a DateTime channel, but we have to get the numbers of seconds to be relative to 0 AD first.  Luckily there's a Channel.Offset property we can use.
Brad Turpin
Message 5 of 12
(8,087 Views)
Hello Brad,
thank your for your response and sorry for my late answer. The start time is 01.01.1970 0:0:0 as indicated in my first post.
How can I change the formats of the channels?
Benjamin
Message 6 of 12
(7,966 Views)
Hi Benjamin,
I'm sorry, I should have seen in your first post that you're referencing the standard Fortran time zero from 1970.  DIAdem uses instead 0 AD, so we need to add the number of seconds between 0 AD and 1970.  Plus, you need to add a property to tell DIAdem to interpret this numeric value as the number of seconds since 0 AD.
Kanal.Offset = 62167132800 + StartTimeMs
Kanal.Properties.Add "displaytype", "Time"
Brad Turpin
Message 7 of 12
(7,948 Views)
Hello Brad,
this was very helpful! I would have never gotten to the line
 by myself.
I am still stuck on the way of adding ms (milliseconds) to the Time format. The values from the file I am reading are in ms. Is there even a way to go downt to ms in the Time format, or is this limited to s (seconds)?
Message 8 of 12
(7,936 Views)
Hi Benjamin,
The numeric channel can contain fractional second values.  If the value in the StartTimeMS variable is in milliseconds, then you need to divide it by 1000 to convert it to seconds before adding it to the recorded values.
Kanal.Offset = 62167132800 + StartTimeMs/1000
Brad Turpin
Message 9 of 12
(7,924 Views)
Full ACK for that, but this only works for the offset. How do I tell Diadem, that each value, that is read is in ms? One possiblity would be to change the values afterwards, but the Values Attribute is read only.
Message 10 of 12
(7,908 Views)
