DIAdem
Change Edit Box Control Backcolor Briefly
I have an apparently simple problem that I cannot solve in the dialog box editor. I have a button and an editbox control on a dialog box and all that is required is that when the button is pressed some text should appear in the editbox and the editbox backcolor should change briefly to another colour before then reverting back. On the basis that the lines of code that change the backcolor will be executed very quickly I have tried to use Pause() just to hold the backcolor for a moment before changing back. However, what seems to happen is the pause is executed before the colour change, so no colour changes are seen. The code is:
Sub Btn_SPAD_EventClick(ByRef This) 'Created Event Handler
  EditBox1.Text = "SPAD"
  EditBox1.BackColor = RGB(95,153,240)
  Pause(1)
  EditBox1.BackColor = -1
End Sub
I have tried various insertions to refresh the textbox or the dialog itself but to no avail. I have also put the Pause in other Subs, like the editbox change or refresh events but also to no avail.
How do I get the backcolor to change briefly before reverting back?
Thanks.
(2,088 Views)
Hi Simon_Aldworth,
Please try the attached SUD.
Greetings
Walter
(2,059 Views)
Accepted by topic author Simon_Aldworth
Thanks Walter. As it happens I managed to find a solution, but I avoided using Pause as that seemed to be causing the problem for me. I found that whenever I used Pause it would interfere with other lines in the same sub, that is to say, the lines didn't seem to execute in order. I used the following in the end:
Sub Btn_StrEquip_EventClick(ByRef This) 'Created Event Handler
  Test = "Steering Equipment"
  SetTest(Test)
End Sub
Sub SetTest(Test)
  Text1.Text = Test
  Text1.BackColor = RGB(95,153,240)
  Dialog.RefreshAll
  xStart = Timer
  Do Until Timer > xStart + 0.3
  Loop
  Text1.BackColor = -1
End Sub
The separate function is irrelevant. I have many buttons on the form all doing similar things so I separated out the function to change the text and backcolour.
Regards.
(2,043 Views)
