DIAdem
Change the order of graphic colouring in Diadem reports
Hi. I am working on a waterfall diagram of various FFT curves. The problem is that Diadem draws the curves to the back of the graph last meaning that much of the curves in front are not fully visible. I have tried rotating the graph by 180 degrees but the same problem occurs. Is there a way of avoiding this? I attach an image to explain.Thanks in advance
Message 1 of 1
(3,938 Views)
