DIAdem
Change x Axis Offset
Hi all together,
I want to compare two meassurement curves with a different starttime, so I have to shift one of the curves in the x axis direction.
How can I shift one of the two curves (change the time offset)? Is there a quick and simple way?
Thanks Michael
(6,856 Views)
Hi Michael,
If you have waveform channels, then you can change the "Waveform x-offset" (wf_start_offset) property of one of them to align them.  If you have XY curves, then you'll need to shift the X values of one of the curves.  You can apply a constant offset to all the values of a channel with the "Scale" function in the "Basics Mathematics" palette of the ANALYSIS panel.  Or you automatically subtract the starting value from the whole X channel for both X channels with the "Offset Correction" function in the same palette.
Brad Turpin
DIAdem Product Support Engineer
(6,846 Views)
