DIAdem
Changing Axis in DIAdem
I'm new to using DIAdem and was wondering how to assign a data channel to a particular axis in DIAdem VIEW. Whenever I drag and drop a channel, it automatically goes to the Y-Axis.
Thanks and Regards
(1,646 Views)
Hi Pranav_k,
The easiest way is to use the Y-axis scaling "n Y-axis". Then a separate Y-axis is automatically created for each curve.
An individual way is to use the setting for scaling “Curve related”. In the dialog a new column appears, and you can edit different scaling for the Y axis.
Greetings
Walter
(1,621 Views)
Hello Walter,
thank you for the detailed desciption.
I use this function very often.
It would be helfpful, if I am able to change the scaling of an y-axis with the mouse. Like it is possible for y-axis in report module (Unfortunately in report module the time x-axis is not adjustable for all y-axises at the same time)
Is a simaliar function planed for view module? Or maybe can I activate a such a function in view, already?
Greetings,
Thorben Lendzian
(1,363 Views)
