DIAdem
Channel Properties Not Correct After Appending Data to Channel
I am using the following fuction to create and append data to a channel group:
Call ArrayToChannels(array, array_names,False, False)
The data appends to each channel correctly.  However, once the channel is appended with the new data, the channel properties are NOT updated.  Specifically, the channel max/min properties are not correct if the appended data would have changed one of those values.  Looking at the data channel shows the values are outside of the min/max property values of the channel.  This is problematic.  Is there a way to make the channel properties refresh?
Thanks.
(4,890 Views)
Update a single channel:
Call ChnCharacter("[3]/Res_Noise_1")
 or all of them
Call ChnCharacterAll()
 you can also find it in the context menue if you right klick on a channel in portal.
(4,870 Views)
