DIAdem
Channel property "NoValues"
i got a channel and the property NoValues is set to "No"
But in help, its written that the values are integer numbers but in data portal i have string.
But when i manually add NOVALUE to numeric channel, after i logfilewrite the value and it returns me value "-1".
look at this, it returns me value which should not exist according to your help.
(3,095 Views)
Accepted by topic author Lukas_Doubek
yes show up as text but it is numeric if you logfile it.
Also, looks like we have different help files... I'm on DIAdem 2019 64 bit service pack 1
(3,029 Views)
OK, so it make sense. thanks.
i got 2017 version still.
i got problem with this function cause it returned me different state that it was in reality. but the problem i found was that the channel was not refreshed after some edits my script made.
I solved it by "refreshing the channel values" by calling this function, after the results matches the data values
Call ChnCharacter(chActive)
(2,995 Views)
@gsklyr wrote:
yes show up as text but it is numeric if you logfile it. happy wheels
Thank you! It resolve my problem
(2,855 Views)
