DIAdem
ChnConcat error message
I have a Problem with the function ChnCocat
i have folow answer:
Error in <append.VBS> (Line: 14, Column: 1):
The target channel (channel/max. length/required: ) is too small.
what can i do ?
i would like merge 2 chanels with 1024 values.
Thomas
(5,628 Views)
Hi Thomas,
Depending on how the "target channel" got created, it may not be a dynamic channel.  In that case you should be able to preset the desired length of that channel like this:
ChnLength("target channel") = ChnLength("target channel") + 1024
... where "target channel" is either the channel name or the channel path ("[1]/target channel") or better still, a channel object variable.
Brad Turpin
DIAdem Product Support Engineer
(5,609 Views)
I have modyfi my script as test
Following Code
'-- VBS script file
'-- Created on 04/30/2015 13:18:41
'-- Author:
'-- Comment:
Option Explicit 'Forces the explicit declaration of all the variables in a script.
CL("Referenz/Test2")=CL("Referenz/Test2")+1024
call chnconcat ("Referenz/Test1","Referenz/Test2")
the Lenght is after 2048 thats correct but the answer of Diadem is the same--
Error in <concat.VBS> (Line: 14, Column: 1):
what is my failure?
thanks
(5,589 Views)
Hi Thomas,
Can you send me that data set?  If you don't want to post it, you can email it to me at brad.turpin@ni.com?  What DIAdem version are you using?
Brad Turpin
(5,582 Views)
It was Diadem 2011
We have now Updated on Version 2014, and now its no Problem.
(5,484 Views)
