DIAdem
ChnFind-Syntax
I am using the search function "ChnFind" in Diadem version 10.2. My function call looks like this:
Dim StartIndex_Hin, MinWinkel
MinWinkel= CCh(Channel,1) ' Search the Minimumvalue in the channel
StartWinkelHin = MinWinkel + 10  ' MinValue + 10
StartIndex_Hin = ChnFind("Ch("&Channel&")>"StartWinkelHin"",0) ' finde the value (StartWinkelHin ) in the Channel
Unfortunately it doesnt work. I get the error that ")" is missing . . . .
When I use the function call:
StartIndex_Hin = ChnFind("Ch(""1/Winkel A"")>10",0)
Everything works good!!!
Can you tell me what am I doing wrong?
thanks for your help!
Message 1 of 9
(7,838 Views)
Hello FHM!
Assuming 'StartWinkelHin' is a VBS variable, DIAdem can not access it in ChnFind! One solution is to convert the value to the string reprsentation like this:
StartIndex_Hin = ChnFind("Ch("&Channel&")>" & str(StartWinkelHin),0) ' finde the value (StartWinkelHin ) in the Channel
Another approach is to use a DIAdem variable for the compare value like R1.
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
Message 2 of 9
(7,833 Views)
Thank you for your quick reply. I test both of them but it didnt work. any another idea ?
Message 3 of 9
(7,826 Views)
Hello FHM!
I will add my complete code. In my test everything works fine!
Option Explicit
Dim Channel
Dim StartWinkelHin
Channel = 2
StartIndex_Hin = ChnFind("Ch("&Channel&") > " & str(StartWinkelHin),0) ' finde the value (StartWinkelHin ) in the Channel
MsgBox StartIndex_Hin
Matthias
Matthias Alleweldt
Twigeater?
Message 4 of 9
(7,823 Views)
thanks for your reply. You are right it works fine as long you use "Channel=2" if you use "Channel="Test" " it wont work any more. The error tells that ")" is needed.
that was and is still the problem Smiley Sad
Message 5 of 9
(7,810 Views)
Hello FHM!
If Channel is a string the code has to look like this:
Option Explicit
Dim Channel
Dim StartWinkelHin
Channel = "Test"
StartIndex_Hin = ChnFind("Ch("""&Channel&""" ) > " & str(StartWinkelHin),0) ' finde the value (StartWinkelHin ) in the Channel
Important are the additional double quotes! A good practice is to display the expression in the ChnFind with a Messagebox like this
There it is easier to see the syntax faults.
Call MsgBox("Ch("""&Channel&""" ) > " & str(StartWinkelHin))
Matthias
Matthias Alleweldt
Twigeater?
Message 6 of 9
(7,805 Views)
Thank you very much it works now!Smiley Happy
Message 7 of 9
(7,801 Views)
I would like to resurect this topic for one clarifiation.Is there a way to call out the GROUP using this method? I'm trying to do a very similar thing, except that I'm searching different channels in different groups.
Thanks in advance.
Message 8 of 9
(6,652 Views)
Hi FCW,
Yes, you can add the Group syntax in several ways instead of your current Ch("ChannelName") syntax:
Ch("GroupName/ChannelName")
Ch("GroupName/[ChannelIndex]")
Ch("[GroupIndex]/ChannelName")
Ch("[GroupIndex]/[ChannelIndex]")
Brad Turpin
DIAdem Product Support Engineer
Message 9 of 9
(6,644 Views)
