DIAdem
ChnNICBdryCalc()
Concerns: Diadem8.1+ Crash Analysis Toolkit
My question is, how works the DIAdem-Command ChnNICBdryCalc() with the NIC Force Type "shear sorce" excactly. Consider it the only the positive X-Forces and also the negative (inverts also the negative to positve)?
For the NIC Force Type "tensile force" its clear for me to split the Z-Force before in positive and negative channels.
Thanks for your help.
(3,807 Views)
The positive and negative parts of your values are calculated separately (without ABS - inverting negative to positive).
positive = (value>=0)* value
negative = (value <0)* value
Theoretical in the signal should be no negative value but from a view of the praxis there is sometimes one. So we use for our calculation the praxis oriented way like the customers wished.
I hope this will help you.
Greetings
Walter Rick
(3,807 Views)
Thanks for help !
Greeetings
Peter
(3,807 Views)
