DIAdem
ChnWfxUnitConvert does not refresh Minimum and Maximum
If I run this script on EXAMPLE date that comes with DIAdem, so 2. ChannelGroup in some Noise:
call ChnWfxUnitConvert(Data.Root.ChannelGroups(2).Channels(1),Data.Root.ChannelGroups(2).Channels(1),"ms")
logfilewrite Data.Root.ChannelGroups(2).Channels(1).Maximum
logfilewrite Data.Root.ChannelGroups(2).Channels(1).Minimum
It rerutns "NOVALUE" and "NOVALUE"
How can I refresh Min and Max props?
(3,765 Views)
Accepted by topic author Radek_Codr
You did not choose the right method.
call UnitConvert(Data.Root.ChannelGroups(2).Channels(1),Data.Root.ChannelGroups(2).Channels(1),"ms")
will change the channel unit.
If min max is not changed
call ChnCharacter(Data.Root.ChannelGroups(2).Channels(1))
can be used to recalculate the values.
P.S.: If you activate the macro recorder and change the unit in dataportal the command shows up in script.
(3,752 Views)
Your metod changes unit of channel, but I need to change X part of waveform channel.
So I used ChnWfxUnitConvert, which does not recalculate characteristic values and ChnCharacter did the job.
Thank you.
(3,722 Views)
Hi Radek_Codr,
Just to be clear here, the Channel.Minimum and Channel.Maximum properties, which were previously CMin(Channel) and CMax(Channel), contain the extrema of the Y values of that channel.  There is no standard Channel property which stores the maximum X value of a channel.  ChnCharacter() will update the Y value extrema properties only.
Brad Turpin
DIAdem Product Support Engineer
(3,701 Views)
