DIAdem
Columns in exported Excel-Sheet?
I'm exporting three data-channels to an excel-sheet after measure, when I open this file, there is always one more column (counting 1,2,3...).
How can I export an excel-file without this column Does somebody know an helping answer?
Nico
(3,470 Views)
Hello Tastenmann,
as far as I know the Export Wizard automatically creates that reverence channel and cannot be told not to do it.
Beside the incrementing numbers it contains the titles of the channel properties that were exported together with the data.
Keep in mind that you may also export DIAdem to Excel via the Windows Clipboard, that means just by using the copy&paste functions. In that case no extra channels will be generated.
I. Schumacher
Application Engineering
(3,470 Views)
