DIAdem
Combining / Concatenating TDMS Files
Hello Everyone,
I need to combine/concatenate several 70mb TDMS files together. I am new to Diadem and see the example Concatenate Channels under scripts and have clicked on it and tried it out but am unable to figure out how to get this script to find my files and put them together. Any help is appreciated.
Wyatt Tubb
wtubb@etainc.org
(2,920 Views)
I created the free app below to make file concatenation easier.  It also manages channel alias names.
http://www.savvydiademsolutions.com/apps.php?topic=apps-bulk-concatenate
(2,835 Views)
Hi wtubb,
If you want to combine TDMS files outside of DIAdem, you can just concatenate them with DOS commands in a batch file.  The TDMS file format is made up of individual sections, think of an array of objects, where each object could contain metadata, channel values, or both.  When streaming buffers to a TDMS file, the streaming program just adds more of these sections/objects to the end of the TDMS file.  Each section contains a pointer at its beginning to the relative position (byte offset) of its end.  So if you've got two TDMS files, TDMS1 and TDMS2, you can just DOS concatenate them together, and it's just like streaming the buffers/sections/objects of TDMS2 to the end of TDMS1.
If Mark's code doesn't suit you for some reason, I can provide example code of how to programmatically create and execute such a batch file in a DIAdem VBScript.
Brad Turpin
Principal Technical Support Engineer
NI
(2,829 Views)
